  • Tang Band W6-1139SIF 6-1/2" Paper Cone Subwoofer Speaker
Tang BandPart # 264-919
Model: W6-1139SIF
The Tang Band W6-1139SIF 6-1/2" driver will surprise and impress when installed in subwoofer systems for compact home theater systems, multimedia setups, and mobile audio installations.
  • 11.5 mm Xmax, amazing low frequency capability for a driver this small!
  • Wide half-roll surround, raised flat spider, and large 1-1/2" 4-layer voice coil ensure exceptional output
  • Vented pole piece and vented spider promote voice coil cooling
  • Features a rugged stamped steel basket and bumped back plate
DS18 ZR6.2D 6-1/2" Elite-Z DVC Subwoofer 2 Ohms Per Coil
Price: $95.95Part # 294-8064
Your Price: $92.69
MSRP: $154.99
Save $62.30 (40%)
Quantity:Qty: 1-3 $92.69/ea
Quantity:Qty: 4+ $88.05/ea
We'll send you an email when Tang Band W6-1139SIF 6-1/2" Paper Cone Subwoofer Speaker is back in stock or available for preorder.
The Tang Band W6-1139SIF 6-1/2" subwoofer's wide half-roll surround, raised flat spider, and large 1-1/2" 4-layer voice coil ensure exceptional output and high power handling. Boasting 11.5 mm of Xmax, the W6-1139SIF is capable of producing prodigious amounts of deep, low-distortion, punchy bass. A vented pole piece and vented spider promote voice coil cooling by improving heat dissipation and reducing efficiency-robbing power compression. This 4 ohm driver also features a rugged stamped steel basket and bumped back plate.
BrandTang Band
ModelW6-1139SIF
Part Number264-919
UPC844632092879
Weight5.95
Nominal Diameter6-1/2"
Power Handling (RMS)50 Watts
Power Handling (MAX)100 Watts
Frequency Response35 to 800Hz
Sensitivity83dB 2.83V/1m
Voice Coil Diameter1.52"
Resonant Frequency (Fs)35Hz
DC Resistance (Re)3.6Ω
Voice Coil Inductance (Le)0.47mH
Mechanical Q (Qms)2.65
Electromagnetic Q (Qes)0.47
Total Q (Qts)0.4
Compliance Equivalent Volume (Vas)0.42ft³
Mechanical Compliance of Suspension (Cms)0.6mm/N
BL Product (BL)8.47T·m
Diaphragm Mass Inc. Airload (Mms)39.91g
Maximum Linear Excursion (Xmax)11.5mm
Surface Area of Cone (Sd)140cm²
Cone MaterialPaper
Overall Outside Diameter6.95"
Baffle Cutout Diameter5.57"
Depth4.33"
Sealed Volume0.2ft³
Sealed F369.4Hz
Vented Volume0.4ft³
Vented F335Hz
